fabianpusch
wo sind da smileys???
grüsse zurück
grüsse zurück
ich habe die brennkamer ein bitsjen ge andert.
Sorry for the bad german language , i am from teh Netherlands
yes its running on kerosine ,and has kero start as wellok, please explain what you have done or changed in the combustion chamber?
your turbine is running with ceroscene?
just take 1,3metre of feulline ,and a full lipo battery.
if the voltage drops under the 7,9 volts then the engine starts to pulse.
hello incone,
that sounds really interesting.
can you make a video of the test bench and run?
that would be really nice
cheers fabian
"Walk around"
I'm impressed by your work
oke ,that was a perfect test run.
de jetjoe junior (kolibri size) is now gone up to 2,2 kg (it was 1,3kg) with egt around the 700 deg, not bad.
as soon as i get more time i will shoot a video from both engines .
Regards,
Martin.
it is almost the same .
the quality of the jjj is good , only needs good balancing.
What sort of unbalance did you se before fixing it? I know for reference that Lambert ballances until under 10mg/mm
Hello Martin "Incone",
you are the one man on "rcuniverse.com" with the pulling tractor with 2 little turbines?
I have seen your pictures, very impressive!
So what is your opinion about the JJJunior?
I was very happy with this little engine, running smooth and accelerating as quick a an old colibri did.
Cheers
Fabian
