JunSi hat nen neuen Lader rausgebracht, den iCharger 208B:
http://www.hillrc.com/EnProductShow.asp?ID=94
Spec.
Input voltage range: 4.5 – 32.0VDC
Charge current range: 0.05 – 20.0A
Discharge current range: 0.05 – 20.0A
Maximum charge power capacity: 350W @ input voltage > 18V
Maximum discharge power capacity: 30W
Maximum extern discharge power capacity: 600W @ 30V/20A
Current drain for balancing: <350mA
Balance accuracy: <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count: 1 – 8 series (In non-balance mode, expand LiFe to 10s)
NiCd/NiMH battery cell count: 1 – 25 series
Pb battery cell count: 1 – 18 series (2 –36V)
Log Files storage: 16Mbit (36 hours)
Battery setup memories: 10
Intelligent temperature control: Yes
PC Connect: USB port
Weight: 420g
Dimensions (L X W X D): 143 x 97 x 26mm (5.63 x 3.82 x 1.02in)
*** URL geändert - Modi ***
Spec.
Weight: 420g
