MarkusD
Gaspar hat wieder mal was innovatives abgeliefert
In the early 2000s, Wren Turbines launched the famous Wren44, the smallest engine available at the time. The diameter of the engine was only 76mm and in its earliest form, the MW44 developed 30N of thrust, later variants increasing to 50N. Its size quickly defined the standard in small engine class, and several manufacturers developed engines of similar size, increasing the power in every new model, currently within the market, this diameter engine covers a range of thrusts, 45N, 50N, 55N, and 70N.
The X90, as all Xicoy engines, push the limit well beyond our competitors, raising the power to 90N, 3 times the power of the original MW44 and with the added benefit of lower overall weight.
Thanks to the FlexThrust technology, the X90 can be used in all aeromodels designed for the MW44 and similar engines of 45N to much bigger models needing up to 90N, greatly improving the choices when looking for your next plane!
As with all Xicoy Engines our purpose designed X90 electronics offers an industry leading simple, lightweight installation. One of The biggest hurdles in Turbine Design is Specific Fuel Consumption (SPFC), the X90 has the lowest TSFC.
Towards the end of the 1990's, Wren developed and set a new standard of small engine known as the MW54. This legendary engine gave a power output of 54N, with a can size of 90mm. It was smaller than the standard at the time, the engines derived from the KJ66 design with can sizes of around 110mm.
Over time, the power increased and many manufacturers developed engines of this 90mm can size, up to a power of 100N.
Our new engine goes one step further again, achieving 120N of thrust with low Specific Fuel Consumption.
The X120 boasts new electronics which keeps up with typical to Xicoy standards, simple lightweight installation and of course it incorporates our FlexThrust Technology giving you anywhere from 60N to 120N at the press of a button. The X120 is perfect for all those popular models that need engines in the range of 60N to 120N. Plenty of kits available to chose from that are of a affordable and practical size. Having an engine that can be used on all of them, the investment on a X120 is a perfect, long term,decision!!
