Was haltet Ihr davon:
http://www.hobbyking.com/hobbyking/...maran_Sailboat_1700mm_RTS_Ready_to_Sail_.html
The Skate 1000 sailboat comes ready to run. All you need to supply is batteries for the transmitter and receiver! Modeled after ocean going racing yachts, the Skates's hull is molded fiberglass composite with a perfect gelcoat and vibrant enamel painted finish. Supporting the colorfully printed rip-stop nylon main sail is a rugged aluminum main mast. All bolt together construction for the three hulls, with easily adjustable rigging, the Skate takes about an hour of assembly to be ready to sail!
A centerline mounted dagger board, along with the outrigger hulls makes the Skate a very stable boat, evein in very high wind conditions. This is an impressive model, good size, that breaks down quickly for transport! Check it out.
Features:
• Ready to Sail - Install battery and you are to sail
• Innovative trimaran design
• Molded fiberglass hull
• Beautiful high gloss painted finish
• Brilliantly printed rip-stop nylon sails
• Removable keel
• Wooden display stand included
• Aluminum main mast
Specs:
Length: 1000mm
Height: 1700mm
Width: 660mm
Area of Sails : 0.4m2
Weight: 1780g
Grüsse
Paul
Features:
• Removable keel
Specs:
Length: 1000mm
Height: 1700mm
Width: 660mm
Weight: 1780g
Grüsse
Paul
