Hiho...
...würde dieser Motor auch im Acromaster gehen?
Model: TR35-48-B
Input Voltage : 7.4V~18.5V (2~5S Li-po)
Kv : 900 rpm/V within 10%
Nb. of turns : 10 Delta
Max. efficiency current : 20~30A
Current capacity : 42A/60s
Internal Resistance : 43 mohm
No Load current @ 7V: 1.83A
Dimensions : 35mm X 55mm / 1.38in X 2.17in
Shaft diameter : 4mm / 0.16in
Weight with cables : 163g / 5.75oz
Number of poles/magnets : 14
Recommended model weight : 1500~2800g / 52~98oz
Power equivalent : .30 to .35 glow engine
Stator Dimentions: 28x26mm
