BWB Brett basierend auf Wipe
mold update
filled with resin added to the pressure points
the problems of deformation due to pressure have been solved
Wipe Glitter ✨
Fix tail with 45 degree cut
“anti-rotation”
Wipe 👽
variant with linkages servo on the back of the profile
much more noise than the servo linkages under profile
Gery
That glitter looks pretty cool, fits the alien theme well :)
I thought about using this:
Your tail mount is great, too!
Are you sure the noise is because of the servo placement? On the first one you used simple wire pushrods, now you have those double clip things ...
You might want to try these:
For a linkage that is completely internal.
Hi, Mark
I build wet on wet do not paint, I add glitter in the resin
IDS System
you don't have much space to mount the servorahmen IDS
unless you make big holes
the self-built IDS system with mj-jet aluminum hinges
Gery
The hypershift pigment can also be used in resin.
If the servos are installed before closing the mold, there is no need for access holes. But then you have to wait for the two halves to cure first.
The MKS DS6100 is 10mm tall, I don't think it would fit in your 80% Wipe anyways.
But your DIY IDS looks very professional! 👍🏼 You give up on the bearing in the frame, but I don't think that matters much.
you are right on the wipe it has little importance it has strong servos and light ailerons
I generally use servos with bearing.
Starting from a uniball and turned to bearing diameter, minimal and light the photo speaks
Der nächste Druck läuft auch schon.
2 Tage 12h und 1kg, für den inneren Teil der Außenflügel (einen der beiden)
3 Umrandungen mit 0.5mm, 0.3mm Schichten, 10% Gyroid Infill
I'm printing at 100%.
My printer is the Mingda Magican Pro (400x400x400mm build volume).
I resectioned the pieces to make use of the full Z height.
Nasses Bandschleifpapier geht ganz gut um Verzug im Druck vom Abkühlen zu entfernen.
Die einzelnen Teile hab ich mit Sekundenkleber zusammengeklebt.
Dann mit Epoxy auf 8mm Furnierplatte Buche. Hier ist auch schon Primer drauf.
Den hab ich dann mit einem Tellerschleifer und Akkuschrauber runtergeschliffen.
An dem linken Stück hatte ich schon probiert die Rillen mit Sekundenkleber zu füllen und schleifen.
Geht auch, aber teurer, langsamer und mehr Arbeit.
Bin noch am Überlegen, ob es nötig ist, über die geschliffene Oberfläche noch 2k Lack zu machen.
Der Primer ist eigentlich hart genug und Polieren geht bestimmt auch,
2k Lack mache ich morgen drauf.
Fürs kolorieren hatte ich an sowas gedacht.
Bin mir aber nicht sicher, ob die weißen Streifen auf der Unterseite noch weiter nach innen sollten.
Moin Marc,
schaut gut aus. Tipp: Schneid alles Gewebe, was nicht fixiert ist nachm tränken mit ner Schablone zu auf ner Folie. Dann verzieht es sich nicht so schnell mehr. Schablonen kann man am simpelsten aus Pappe oder Depron machen.
Lukas
