midgetmustang
Denis,
like you said, there was maybe a problem with the Q40. But this engines are not comparable in the RPM range to the Q500 engines.
mm
Edit, i need to add this, which Dave wrote:
The vibration level of the SS vs. LS is a non-issue. I can easily make an SS vibrate more than an LS by incorrect mounting and setup of the counterweight. The real issue is that the LS makes a lot more power than the SS and runs the props at a significantly higher in-air RPM, close to 1500 according to the data logger under ideal conditions.
Nochmals, in klaren Worten, bei bestimmungsgemäßem Gebrauch von Propeller und Motor diskutieren wir hier über ein bei Q500 nicht existentes Problem.
mm
mm
mm
