Ville
Hello Ville,
this motor is to large in diameter and to heavy, if you get an 4s Lipo. The diameter should be less than 31 mm. The motor mount also should be 31mm in diameter. I bought him here:
http://www.kd-modelltechnik.de/shop...otorspant-Lochkreis-1619mm-DA-31mm::1286.html
Since the fuselage is oval, I would not cut it further back! Otherwise it looks like here:
http://www.rcgroups.com/forums/showthread.php?t=1239669
An alternative motor:
Mega 16/25/2 with Kontronik-Gear KPG 25 5,2:1
or
NeuMotor 1110/1.5Y/3.2 (3025U/V) with Kontronik-Gear KPG 25 5,2:1
or
NeuMotor 1110/3D (2800U/V) with Kontronik-Gear KPG 25 5,2:1
If you have further questions, ask!
kindly
Matthias
Hello again Matthias
I wonder if is the same electro-fuse we are talking about. Look at the following link.
http://www.rcgroups.com/forums/showpost.php?p=19542935&postcount=310
This is the fuselage I bought but not recived yet.
I was told that the Poly-Tec 490-23 would fit, maybe there has been some misuderstanding between me and the dealer?
This I must check as soon as possible.
Maybe you did a conversion from the standard Aspire that you can see in the this link.
As for the weight of the motor, I would like the Aspire a little heavier for windy days.
Thanks so much for your motor recommendations and other info. I have got a MEGA 16/25/2 PG 3,8:1 that I can use.
http://www.megamotor.cz/v3/script/default.php?&sid=6b72359c5c9a8e65f339676eb7ae6320&page_id=lang_eng
Damn, it not so easy when there ar so little/bad info before buying a motor.
By the way, where can I buy this Kontronik-Gear KPG 25 5,2:1?
Anyhow, thanks again
/Ville
