[QUOTE = "hps, post: 7550057, member: 29694"]
... The connections to the motor are also made. Here you should take your time and lay the three connection cables one behind the other. I used a piece of the push tube foil to stiffen it. If you lay the connection cables across, that means more than twice the resistance and that should not be neglected! Small cause, big effect !
In addition, you should try to "hide" the wiring harness behind a stator blade:
Currently finishing my build of the Viper and I'm looking for instructions on how to solder the EDF motor wires to the wires leading to the ESC. Any advice on how to proper solder them the way as Peter did in the attached picture?
Momentan bin ich mit dem Aufbau der Viper fertig und suche nach Anweisungen zum Löten der EDF-Motorkabel an die Drähte, die zum Regler führen. Irgendwelche Ratschläge, wie man sie richtig löt, wie es Peter auf dem beigefügten Bild getan hat?
