Ja, diese "Abstandsregeln" sind von den sogenannten "
Acceptable Means of Compliance" der "EASA" abgeschrieben,
ohne dass dies kenntlich gemacht wird. Das ist zumindest intransparent!
Ganz abgesehen vom zweifelhaften Rechtscharakter als sogenanntes "
Soft Law".
EASA | European Union Aviation Safety Agency: The European Union Authority for aviation safety
www.easa.europa.eu
issuing Acceptable Means of Compliance and Guidance Material to Commission Implementing Regulation (EU) No 2019/947 ‘Rules and procedures for the operation of unmanned aircraft’
www.easa.europa.eu
Und hier konkret:
www.easa.europa.eu
AMC1 UAS.OPEN.040(1) Operations in subcategory A3
AREAS WHERE UAS OPERATIONS IN A3 MAY BE CONDUCTED
(a) If an uninvolved person enters the range of the UAS operation, the remote pilot should, where
necessary, adjust the operation to ensure the safety of the uninvolved person and discontinue
the operation if the safety of the UAS operation is not ensured.
(b) A minimum horizontal distance from the person that is passing the area could be estimated as
follows:
(1) no less than 30 m;
(2) no less than the height (‘1:1 rule’, i.e. if the UA is flying at a height of 30 m, the distance
of the UA from the uninvolved person should be at least 30 m), and
(3) no less than the distance that the UA would cover in 2 seconds at the maximum speed
(this assumes a reaction time of 2 seconds).
This minimum horizontal distance is intended to protect people on the ground, but can be
extended to property and animals.
Der bemannten Luftfahrt nahestehende Organisationen scheinen grundsätzlich "Advanced Means of Compliance" als EASA-gottgegeben zu bejahen und als gesetzesgleich anzunehmen. Und manch Modellflugverband scheint dies nicht zu hinterfragen.
