Hi i have found a problem with the graupner hott system. The receivers interfere with the baro of both the dji wookong and the ys-x6. As soon as the receiver antenna comes within 20cm of the imu's the baros will go crazy. With futaba and spectrum I don't have these issues. Any ideas on how to fix this. Beceause multicopters are small you can't put the reciever further away. Thank you and sorry dass dieser beitrag nicht im Deutsch ist, das war zu schwirig fur mich.
that's the first time I've heard about such an issue - I'm using three of DJI's NAZA (which should have the same barometric sensors as fas as I know) all with Graupner Gr-24 Hott receivers and a MX-20. The antennas of the Gr-24 all are close to the NAZAs, but never noticed all failure in altitude holding. What do you mean with 'go crazy'? Which receivers do you use?
