Hello, also got my v3 339 from Jean Marc, thanks!
the UAT is now round and clear and not white and square like before,
just wish the fill/drain pipe could be elongated to the bottom so all can be drained out without flipping model upside down ,
the pipes are cut in the cap so I cant just add some tubing to the bottom of UAT,
but thats ok,
I observed my door servo heating up, consuming 0.8A during opened doors,
sems ball link is placed to the back and not to the front like on the other side servo,
after switching it to the front buzzing, heating stopped and current draw went to almost zero, so check that out too.
did you also get ncie scale ( pink
) cockpit layout
had to enlarge holes to reach elevator screws, so will look into something to plug them,
some rubber caps or similar, maybe someone has some better idea?
K80 G2 will be installed (heavy I know)
